Configuring Data Warehouse for Smart Card and certificate login
You must modify the OnCommand Insight Data Warehouse configuration to support Smart Card (CAC) and certificate logins.
Before you begin
LDAP must be enabled on the system.
The LDAP
User principal account nameattribute must match the LDAP field that contains a user's government ID number.The common name (CN) stored on government-issued CACs is normally in the following format:
first.last.ID. For some LDAP fields, such assAMAccountName, this format is too long. For these fields, OnCommand Insight extracts only the ID number from the CNs.
If you have changed server.keystore and/or server.trustore passwords using securityadmin, restart the sanscreen service before importing the LDAP certificate. |
For the most up to date CAC and Certificate instructions, see the following Knowledgebase articles (Support login required): |
Steps
Use regedit to modify registry values in
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Apache Software Foundation\Procrun2.0\SANscreen Server\Parameters\Java-
Change the JVM_Option
-DclientAuth=falseto-DclientAuth=true.
For Linux, modify the
clientAuthparameter in/opt/netapp/oci/scripts/wildfly.server -
Add certificate authorities (CAs) to the Data Warehouse trustore:
In a command window, go to
..\SANscreen\wildfly\standalone\configuration. -
Use the
keytoolutility to list the trusted CAs:C:\Program Files\SANscreen\java64\bin\keytool.exe -list -keystore server.trustore -storepass <password>
See the SecurityAdmin documentation for more information about setting or changing the password for server_trustore.The first word in each line indicates the CA alias.
If necessary, supply a CA certificate file, usually a
.pemfile. To include customer's CAs with Data Warehouse trusted CAs go to..\SANscreen\wildfly\standalone\configurationand use thekeytoolimport command:C:\Program Files\SANscreen\java64\bin\keytool.exe -importcert -keystore server.trustore -alias my_alias -file 'path/to/my.pem' -v -trustcacertsmy_alias is usually an alias that would easily identify the CA in the
keytool -listoperation.
On the OnCommand Insight server, the
wildfly/standalone/configuration/standalone-full.xmlfile needs to be modified by updating verify-client to "REQUESTED" in/subsystem=undertow/server=default-server/https-listener=default-httpsto enable CAC. Log in to the Insight server and run the appropriate command:OS
Script
Windows
<install dir>\SANscreen\wildfly\bin\enableCACforRemoteEJB.bat
Linux
/opt/netapp/oci/wildfly/bin/enableCACforRemoteEJB.sh
After executing the script, wait until the reload of the wildfly server is complete before proceeding to the next step.
Restart the OnCommand Insight server.
