Transition preparation checklist
Before you start transition, you should verify that you have met all of the prerequisites for transition.
ONTAP version requirements
| Item | Yes |
Supported 7-Mode version NetApp Interoperability Matrix Tool |
Your cluster must be running one of the following Data ONTAP versions:
You must transition to one of the following ONTAP releases:
Licensing requirements
| Item | Yes |
SnapMirror license is enabled on the 7-Mode system |
SnapMirror licenses are enabled on the primary and secondary clusters for transitioning a volume SnapMirror relationship |
CIFS license is enabled on the cluster, if it is enabled on the 7-Mode system |
NFS license is enabled on the cluster, if it is enabled on the 7-Mode system |
iSCSI license is enabled on the cluster, if it is enabled on the 7-Mode system |
FC license is enabled on the cluster, if it is enabled on the 7-Mode system |
Other feature licenses, if available on the 7-Mode system, are added to the cluster |
SnapMirror requirements on the 7-Mode system
| Item | Yes |
SnapMirror license |
Verify if one of the following is true:
Volume settings on the 7-Mode system
| Item | Yes |
Volume is online |
Volume is not restricted |
The following volume options are disabled:
Managing access to the cluster
| Item | Yes |
SSL is enabled
HTTPS is allowed on the cluster-management LIF
Managing access to the 7-Mode system
| Item | Yes |
HTTPS is enabled
SSL is enabled
SSLv2 and SSLv3 are disabled
Networking requirements
| Item | Yes |
Cluster is reachable using the cluster-management LIF |
One or more intercluster LIFs are set up on each node of the cluster For multipathing, two intercluster LIFs are required on each node |
Static routes are created for the intercluster LIFs |
7-Mode system and cluster are reachable from the Windows system on which 7-Mode Transition Tool is installed |
NTP server is configured and the 7-Mode system time is synchronized with the cluster time |
Port requirements
| Item | Yes |
7-Mode system
Cluster
NFS requirements
| Item | Yes |
NFS license is added to the cluster |
DNS entry must be configured for AD domain on the SVM |
NFS is added to the list of allowed protocols for the SVM |
Clock skews between KDC and the cluster is less than or equal to 5 minutes |
CIFS requirements
| Item | Yes |
CIFS license is added to the cluster |
If MultiStore license is enabled, CIFS must be added to the list of allowed protocols for the vFiler unit that owns the transitioning volumes |
CIFS is set up and running on the 7-Mode system |
Authentication type in 7-Mode for CIFS is Active Directory (AD) or Workgroup |
CIFS is added to the list of allowed protocols for the SVM |
DNS is configured for the SVM |
CIFS server is configured for the SVM |
CIFS is running on the SVM |
Related information
