cluster agent connection modify
Modify Cloud Agent connection
Modify agent connection properties.
- -name <text>- Name (privilege: advanced)
Specify connection name.
- [-destination <text>]- Destination URL (privilege: advanced)
Specify destination URL. For secure WebSocket, this should be amqpwss://<host[:port]>.
- [-use-proxy {true|false}]- Use Proxy (privilege: advanced)
Establish this connection through the HTTP proxy server associated with this connection's IPspace.
- [-subscribe-address <text>]- Subscribe Address (privilege: advanced)
AMQP address to which ONTAP will subscribe. Defaults to "ontap.agent.manager".
- [-publish-address <text>]- Publish Address (privilege: advanced)
AMQP address to which ONTAP will publish. Defaults to "ontap.agent.cluster".
- [-certificate-uuid <UUID>]- Authentication Certificate UUID (privilege: advanced)
Specify UUID of an existing certificate to use for authentication to the destination.
- [-csr-token <text>]- Authentication CSR Token (privilege: advanced)
Token for authenticating with CSR URL. Not audited.
- [-idle-timeout <integer>]- Idle Timeout (in seconds) (privilege: advanced)
AMQP idle timeout. Defaults to 0. If set, the local peer will disconnect if it does not receive AMQP frames within the timeout.
- [-address-family {unknown|ipv4|ipv6}]- Address Family (privilege: advanced)
Specify address family.
- [-auto-delete-error-minutes {<integer>|-}]- Time to Auto-delete when disconnected (in minutes) (privilege: advanced)
Specify time to live in minutes for cloud agent connection in error state. Connection will be deleted if it stays in error state beyond this time.
cluster-1::> cluster agent connection modify -name cloud_agent -destination amqpwss://new-manager.example.com
 PDFs
PDFs
