event filter test
Test an event filter
The event filter test
command is used to test an event filter. When specified with a message name, the command displays whether the message name is included or excluded from the filter. When specified without a message name, the command displays the number of events from the catalog that match the filter. For more information, see the event filter create command.
-filter-name <text>
- Filter Name-
Use this mandatory parameter to specify the name of the event filter to test.
[-message-name <Message Name>]
- Message Name-
Use this optional parameter to specify the message name of the event to test against the filter.
The following example tests an event filter named err-wafl-no-scan-but-clone:
cluster1::> event filter show Filter Rule Rule SNMP Trap Name Posn Type Message Name Severity Type Parameters ----------- ---- -------- ---------------- ------------- --------- ----------- default-trap-events 1 include * EMERGENCY, ALERT * *=* 2 include * * Standard, Built-in *=* 3 exclude * * * *=* err-wafl-no-scan-but-clone 1 include wafl.scan.clone.* * * *=* 2 exclude wafl.scan.* * * *=* 3 include wafl.* EMERGENCY, ALERT, ERROR * *=* 4 exclude * * * *=* important-events 1 include * EMERGENCY, ALERT * *=* 2 include callhome.* ERROR * *=* 3 exclude * * * *=* no-info-debug-events 1 include * EMERGENCY, ALERT, ERROR, NOTICE * *=* Filter Rule Rule SNMP Trap Name Posn Type Message Name Severity Type Parameters ----------- ---- -------- ---------------- ------------- --------- ----------- no-info-debug-events 2 exclude * * * *=* 12 entries were displayed. cluster1::> event filter test -filter-name err-wafl-no-scan-but-clone 271 events will be included in the given filter. cluster1::> event filter test -filter-name err-wafl-no-scan-but-clone -message-name wafl.scan.clone.split.cantLock The message-name "wafl.scan.clone.split.cantLock" is included in the given filter. cluster1::> event filter test -filter-name err-wafl-no-scan-but-clone -message-name wafl.scan.layout.cantWrite The message-name "wafl.scan.layout.cantWrite" is excluded from the given filter.
