ONTAP commands
lun igroup initiator add-proximal-vserver
Add a Vserver to the initiator's proximal list
This command is used to configure which site in a SnapMirror Active Synchronous (SM-AS) relationship is proximal with the provided FCP or iSCSI initiator.
-vserver <Vserver Name> - Vserver (privilege: advanced)
Specifies the name of the Vserver the initiator will access.
-initiator <text> - Initiator (privilege: advanced)
Specifies the FCP WWPN or iSCSI IQN of the initiator.
-proximal-vservers <text>,…​ - Proximal Vserver Name (privilege: advanced)
Specifies the name of the Vserver to configure as proximal. The specified Vserver must either be the same as the -vserver parameter or a Vserver in a peer relationship with snapmirror as an allowed application.
[-replace <true>] - Replace Existing (privilege: advanced)
If true, replace all existing -proximal-vservers for the initiator with the ones specified. By default, the specified -proximal-vservers are added to any existing values.
The following example configures iqn.2001-04.com.example:uefi-0232314 in Vserver local-vserver as proximal to the peer-vserver Vserver:
cluster1::*> lun igroup initiator add-proximal-vserver -vserver local-vserver -initiator iqn.2001-04.com.example:uefi-0232314 -proximal-vservers peer-vserver
