network bgp peer-group delete
Delete a BGP peer group
The network bgp peer-group delete command is used to delete border gateway protocol (BGP) peer group configuration.
-ipspace <IPspace>- IPspace Name-
This parameter specifies the IPspace of the BGP peer group being deleted.
 -peer-group <text>- Peer Group Name-
This parameter specifies the name of the BGP peer group being deleted.
cluster1::> network bgp peer-group delete -ipspace Default -peer-group group1
