Command reference
network bgp peer-group delete
Delete a BGP peer group
The network bgp peer-group delete command is used to delete border gateway protocol (BGP) peer group configuration.
-ipspace <IPspace> - IPspace Name
This parameter specifies the IPspace of the BGP peer group being deleted.
-peer-group <text> - Peer Group Name
This parameter specifies the name of the BGP peer group being deleted.
cluster1::> network bgp peer-group delete -ipspace Default -peer-group group1
