security key-manager delete-key-database
(DEPRECATED)-Deletes the key hierarchy for the Onboard Key Manager
This command is deprecated and might be removed in a future release. Use security key-manager onboard disable instead. |
The security key-manager delete-key-database command permanently deletes the Onboard Key Manager configuration from all nodes of the cluster.
The following example deletes the Onboard Key Manager configuration from all nodes of the cluster:
cluster-1::*> security key-manager delete-key-database
Warning: This command will permanently delete all keys from the Onboard Key Manager.
Do you want to continue? {y|n}: y
