ONTAP commands
security webauthn credentials show
Show Webauthn Credentials Data
The security webauthn credentials show displays information on the FIDO2/WebAuthn registered credentials.
{ [-fields <fieldname>,…​]
Selects the fields that you specify.
| [-instance ] }
Displays all the fields for the FIDO2/WebAuthn registered credentials.
[-vserver <vserver name>] - Vserver
Selects the FIDO2/WebAuthn registered credentials that match this parameter value. Only cluster-level credentials are supported at this time.
[-username <text>] - Username
[-index <integer>] - Index
[-rpId <text>] - Relying Party ID
[-credential-id-sha <text>] - SHA-256 Hashed Credential ID
[-publickey-algorithm <text>] - Public Key Algorithm
[-publickey <text>] - Public Key
[-display-name <text>] - Display Name
[-credential-type <public-key>] - Credential Type
[-rpName <text>] - Relying Party Name
[-creation-time <MM/DD/YYYY HH:MM:SS>] - Creation Time
[-last-used <MM/DD/YYYY HH:MM:SS>] - Last Used
[-scope {svm|cluster}] - Cluster or SVM
The example below displays information on the FIDO2/WebAuthn registered credentials:
cluster1::> security webauthn credentials show
Vserver: cluster1
                              Username: admin
                                 Index: 0
                      Relying Party ID: myontap.example.com
          SHA-256 Hashed Credential ID: aaaaaaaaaaaaaaaaaaaaaaaaaaa
                  Public Key Algorithm: ES256
                            Public Key: abcd=
                          Display Name: admin
                       Credential Type: public-key
                    Relying Party Name: myontap.example.com
                         Creation Time: 6/10/2024 15:01:00
                             Last Used: 6/10/2024 15:01:00
