ONTAP commands
security webauthn supported-algorithms show
Show WebAuthn Supported Algorithms
The security webauthn supported-algorithms show displays information on the FIDO2/WebAuthn supported algorithms.
{ [-fields <fieldname>,…​]
Selects the fields that you specify.
| [-instance ] }
Displays all the fields for the FIDO2/WebAuthn supported algorithms.
[-vserver <vserver name>] - Vserver
Selects the FIDO2/WebAuthn settings that match this parameter value. If not specified, all cluster-level and Vserver-level settings are displayed.
[-alg-name <text>] - Algorithm Name
[-alg-id <integer>] - Algorithm ID
[-alg-type <public-key>] - Algorithm Type
[-scope {svm|cluster}] - Cluster or SVM
The example below displays information on the FIDO2/WebAuthn supported algorithms:
cluster1::> security webauthn supported-algorithms show
Vserver: cluster1
ID         Name        Type
    -7     ES-256      public-key
   -35     ES-384      public-key
  -257     RS-256      public-key
3 entries were displayed.
