ONTAP commands
snapmirror mediator tba-history show
Show Mediator Agent Event History
The snapmirror mediator tba-history show command shows the history of the ONTAP Mediator Agent events..
{ [-fields <fieldname>,…​]
| [-instance ] }
[-cg-rel-uuid <UUID>] - Cg Relationship Uuid
Cg Relationship Uuid.
[-start-time <MM/DD/YYYY HH:MM:SS>] - TBA Task Start Time
Mediator Agent Task Start Time.
[-token-num <integer>] - Token Number
Token Number.
[-cg-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[app-cgname]>}] - Cg Path
Cg Path.
[-aux-generation-num <integer>] - Auxillary Generation Number
Auxiliary Generation Number.
[-cg-rel-task <text>] - TBA Task Type
Mediator Agent Task Type.
[-cg-rel-state {invalid-state|waiting|task-processing|task-complete}] - Cg Management State
Cg Management State.
[-end-time <MM/DD/YYYY HH:MM:SS>] - TBA Task End Time
Mediator Agent Task End Time.
[-cg-rel-action {invalid|none|continue|stop|failover-incapable|auto-failover|success|failed|mismatch|retry|success-pending|stop-pending|continue-pending|failover-incapable-pending|try-failover-incapable-ic|try-failover-incapable-med|try-auto-failover}] - Cg Management Action
Cg Management Action.
[-errCode <integer>] - Error Code for Task Failure
Error Code for Task Failure.
The following example shows the list of mediator configurations.
C1_sti89-vsim-ucs525q_cluster::> snapmirror mediator tba-history show
        (snapmirror mediator tba-history show)
      Path         Token API   Event   Start Time  State      End Time   Action
      vs0:/cg/cg1_src 5  4     Process Set Resync Context 4/28/2021 11:09:52 task-complete 4/28/2021 11:09:52 continue
      vs0:/cg/cg1_src 6  1     Process Master InSync 4/28/2021 11:10:08 task-complete 4/28/2021 11:10:08 success
      2 entries were displayed.
      C1_sti89-vsim-ucs525q_cluster::> snapmirror mediator tba-history show -instance
Cg Relationship Uuid: ad49a4f1-a833-11eb-9846-005056a7c906
       Mediator Agent Task Start Time: 4/28/2021 11:09:52
             Token Number: 5
             Cg Path: vs0:/cg/cg1_src
    Auxillary Generation Number: 4
       Mediator Agent Task Type: Process Set Resync Context
      Cg Management State: task-complete
   Mediator Agent Task End Time: 4/28/2021 11:09:52
     Cg Management Action: continue
    Error Code for Task Failure: 0
       Mediator Agent Task Start Time: 4/28/2021 11:10:08
             Token Number: 6
    Auxillary Generation Number: 1
       Mediator Agent Task Type: Process Master InSync
   Mediator Agent Task End Time: 4/28/2021 11:10:08
     Cg Management Action: success
