ONTAP commands
snapmirror release
Remove source information for a SnapMirror relationship
The snapmirror release command removes the relationship information from the source Vserver. The command also removes any snapshot owner tags and any snapshots which were created for the specified relationship from the source volumes. It does not destroy any volumes or Vservers. This command must be used from the source Vserver or cluster.
For relationships with a policy of type strict-sync-mirror , it additionally resumes primary volume access if the IO was restricted because the relationship was OutOfSync.
For relationship having Application Consistency Groups, snapmirror release command used on the source of a Application Consistency Group relationship, removes the relationship information from the source side and deletes snapshots which were created on the source volumes.
You can use the snapmirror list-destinations command to display source Vservers' relationship information. This information is populated during the first SnapMirror transfer, not when the snapmirror create command is issued.
This command is not supported for SnapMirror relationships with the field "Relationship Capability" showing as "Pre 8.2" in the output of the snapmirror show command.
This command is not supported for SnapMirror relationships with non-ONTAP endpoints.
The snapmirror release operation fails if a SnapMirror transfer for the SnapMirror relationship is in a data phase of the transfer.
{ [-S, -source-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[app-cgname]>}] - Source Path
| [-source-vserver <vserver name>] - Source Vserver
Specifies the source Vserver of the SnapMirror relationship. For relationships with volumes as endpoints, if this parameter is specified, parameter -source-volume must also be specified.
[-source-volume <volume name>] - Source Volume }
Specifies the source volume of the SnapMirror relationship. If this parameter is specified, parameter -source-vserver must also be specified.
{ -destination-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[app-cgname]>} - Destination Path
| -destination-vserver <vserver name> - Destination Vserver
Specifies the destination Vserver of the SnapMirror relationship. For relationships with volumes as endpoints, if this parameter is specified, parameter -destination-volume must also be specified.
[-destination-volume <volume name>] - Destination Volume }
Specifies the destination volume of the SnapMirror relationship. If this parameter is specified, parameter -destination-vserver must also be specified.
[-relationship-info-only <true>] - Remove relationship info only (skip cleanup of snapshots)
If this parameter is specified, the cleanup of snapshots is bypassed and only the source relationship information is removed. It is recommended to specify this parameter only when the source volume is not accessible.
[-relationship-id <UUID>] - Relationship ID
This optional parameter specifies the relationship identifier of the relationship. It must be specified when information for more than one relationship with the same source and destination paths is present. This parameter is not supported for Vserver SnapMirror relationships.
[-f, -force <true>] - Force
If this parameter is specified, the command proceeds without prompting for confirmation.
To release the Application Consistency Group SnapMirror relationship with the destination Application Consistency Group cg_dst in Vserver vs2.example.com and the source Application Consistency Group cg_src in Vserver vs1.example.com , type the following command from the source cluster:
source::> snapmirror release
        vs2.example.com:/cg/cg_dst
To release just the source information but not remove the snapshots that might be needed for a subsequent resync for the Asynchronous SnapMirror Application Consistency Group relationship with the destination Application Consistency Group cg_dst in Vserver vs2.example.com , type the following command:
vs2.example.com::> snapmirror release
       -destination-path vs2.example.com:/cg/cg_dst
       -relationship-info-only true
To release the SnapMirror active sync relationship with the destination Consistency Group cg_dst in Vserver vs2.example.com and the source Consistency Group cg_src in Vserver vs1.example.com , type the following command from the source cluster:
