snapmirror resync
Start a resynchronize operation
The snapmirror resync command establishes or reestablishes a mirroring relationship between a source and a destination endpoint. The endpoints can be Vservers, volumes, Application Consistency Groups or non-ONTAP endpoints that support SnapMirror. snapmirror resync for a SnapMirror relationship with volumes as endpoints is typically executed in the following cases:
The destination mirror is broken (that is, the destination volume is a read-write volume and no longer a data protection mirror). After the
snapmirror resynccommand completes, the destination volume is made a data protection mirror and the mirror can be manually updated or scheduled for updates. -
snapmirror update command failed because the required common snapshot was deleted on the source volume.
The volumes are the first and third endpoints in a cascade chain of relationships and they have a common snapshot. In this case,
snapmirror resyncmight implicitly create the SnapMirror relationship between them.
The snapmirror resync command can cause data loss on the destination volume because the command can remove the exported snapshot on the destination volume.
The default behavior of the snapmirror resync command for volume relationships is defined as follows:
Finds the most recent common snapshot between the source and destination volumes, removes snapshots on the destination volume that are newer than the common snapshot and mounts the destination volume as a DP volume with the common snapshot as the exported snapshot.
For data protection (DP) relationships, takes a snapshot of the source volume to capture the current image and transfers snapshots that are newer than the common snapshot from the source volume to the destination volume. For extended data protection (XDP) relationships, transfers snapshots newer than the common snapshot according to the relationship policy, i.e., snapshots will match rules associated with the policy as defined by the
snapmirror policycommands. For relationships associated withsnapmirror policyof typeasync-mirrorandmirror-vaultthesnapmirror resyncfirst takes a snapshot of the source volume and includes it in the snapshots selected for transfer. -
For a SnapLock Compliance volume in an XDP relationship with SnapMirror policy of type async-mirror, if SnapMirror resync operation detects data divergence between the common snapshot and the AFS on the destination volume, the resync operation preserves the data changes in a locked snapshot for the duration of the current volume expiry time. If the volume expiry time is in the past or has not been set, then the snapshot is locked for a duration of 30 days. The common snapshot is also locked for the same duration.
For Vserver SnapMirror relationships, a resync operation is typically executed when the relationship is broken-off, the subtype of the destination Vserver is default and the destination volumes are of type read-write. Once the command is queued, the subtype of the destination Vserver changes from default to dp-destination . A successful resync operation also makes the destination Vserver's volumes data protection volumes.
If the resync command is executed on a Vserver SnapMirror relationship, and the corresponding source and destination Vservers have volumes with volume level SnapMirror relationships, then the volume level SnapMirror relationships will be converted to volumes under the Vserver SnapMirror relationship. This conversion is supported only for source and destination Vservers which have been transitioned from a 7-Mode vFiler into a C-Mode Vserver. Some basic pre-requisites for the conversion are that the destination Vserver should be in a stopped state and all the destination Vserver volumes except the root volume should be in a volume level SnapMirror relationship with volumes of the source Vserver. The state of these volume level SnapMirror relationships should be Snapmirrored and status should be Idle .
When the destination Application Consistency Group relationship is broken-off, the snapmirror resync changes the destination Application Consistency Group to read-only and the relationship will be SnapMirrored.
snapmirror resync for a relationship with a policy of type strict-sync-mirror or sync-mirror is typically executed in the following case:
The destination mirror is broken (that is, the destination volume is read-write and no longer read-only). After the
snapmirror resynccommand completes, the destination volume changes to read-only and the relationship to InSync.
The snapmirror resync command is typically not required to return a relationship that has fallen out of sync due to an error condition to InSync because SnapMirror has Auto Resync for synchronous relationships. When SnapMirror detects that the relationship has fallen out of sync for any reason other than a snapmirror quiesce , snapmirror break or snapmirror delete command was executed on the relationship, it will automatically initiate a resync operation.
The default behavior of the snapmirror resync command for relationships with a policy of type strict-sync-mirror or sync-mirror is defined as follows:
Creates a snapshot on the destination of the current image of the destination file system. This snapshot becomes the exported snapshot for the volume during the resync operation.
Finds the most recent common snapshot between the source and destination volumes. Performs a local rollback transfer to give the active file system the same data as the common snapshot. It then loops through a sequence, creating a snapshot on the source volume, transferring the data captured in that snapshot, creating a snapshot of the data on the destination, and repeating until the relationship is close to InSync. After the last transfer, it enters cutover to bring the relationship to InSync.
User-created snapshots are not replicated by a resync operation.
At the conclusion of the resync operation, the exported snapshot on the destination is removed and the client will then see the active file system on the destination volume. The relationship will be InSync and periodic creation of common snapshots will resume.
The snapmirror resync command supports an optional parameter "preserve" . The parameter "preserve" is only supported for extended data protection (XDP) relationships. It is not supported for relationships with a non-ONTAP endpoint. It is not supported for relationships with a policy of type strict-sync-mirror and sync-mirror . When used, the parameter "preserve" changes the behavior of the snapmirror resync command. The changed behavior of the command can be described as follows:
Finds the most recent common snapshot between the source and destination volumes, preserves all snapshots on the destination volume that are newer than the common snapshot, and mounts the destination volume as a DP volume with the common snapshot as the exported snapshot.
Performs a local rollback transfer to make a copy of the common snapshot on the destination volume and establish it as the latest snapshot on the destination volume. The command then transfers all snapshots that are newer than the common snapshot, from the source volume to the destination volume. The command only transfers snapshots that match the relationship's policy, i.e., snapshots will match rules associated with the policy as defined by the
If a SnapMirror relationship does not already exist, that is, the relationship was not created using the snapmirror create command, the snapmirror resync command will implicitly create the SnapMirror relationship, with the same behaviors as described for the snapmirror create command before resyncing it.
For Vservers, you must create SnapMirror relationships between Vservers by using the snapmirror create command before you run the snapmirror resync command. The snapmirror resync command does not implicitly create the relationship.
This command is supported for SnapMirror relationships with the field "Relationship Capability" showing as either "8.2 and above" or "Pre 8.2" in the output of the snapmirror show command.
For relationships with "Relationship Capability" of "8.2 and above" , you can track the progress of the operation using the snapmirror show command.
For relationships with "Relationship Capability" of "Pre 8.2" , a job will be spawned to operate on the SnapMirror relationship, and the job id will be shown in the command output. The progress of the job can be tracked using the job show and job history show commands.
The snapmirror resync command fails if the destination volume does not have a snapshot in common with the source volume.
The snapmirror resync command does not work on load-sharing mirrors.
The snapmirror resync command must be used from the destination Vserver or cluster.
[-S, -source-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[app-cgname]>}]- Source Path - |
[-source-cluster <Cluster name>]- Source Cluster -
Specifies the source cluster of the SnapMirror relationship. If this parameter is specified, the
-source-vserverand-source-volumeparameters must also be specified. This parameter is only applicable for relationships with"Relationship Capability"of"Pre 8.2". This parameter cannot be specified when operating in a Vserver context on relationships with"Relationship Capability"of"8.2 and above". [-source-vserver <vserver name>]- Source Vserver-
Specifies the source Vserver of the SnapMirror relationship. For relationships with volumes as endpoints, if this parameter is specified, parameters
-source-volumeand for relationships with"Relationship Capability"of"Pre 8.2",-source-clustermust also be specified. This parameter is not supported for relationships with non-ONTAP source endpoints. [-source-volume <volume name>]- Source Volume }-
Specifies the source volume of the SnapMirror relationship. If this parameter is specified, parameters
-source-vserverand for relationships with"Relationship Capability"of"Pre 8.2",-source-clustermust also be specified. This parameter is not supported for relationships with non-ONTAP source endpoints. - {
-destination-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[app-cgname]>}- Destination Path - |
[-destination-cluster <Cluster name>]- Destination Cluster -
Specifies the destination cluster of the SnapMirror relationship. If this parameter is specified, parameters
-destination-vserverand-destination-volumemust also be specified. This parameter is only applicable for relationships with"Relationship Capability"of"Pre 8.2". This parameter cannot be specified when operating in a Vserver context on relationships with"Relationship Capability"of"8.2 and above". -destination-vserver <vserver name>- Destination Vserver-
Specifies the destination Vserver of the SnapMirror relationship. For relationships with volumes as endpoints, if this parameter is specified, parameters
-destination-volumeand for relationships with"Relationship Capability"of"Pre 8.2",-destination-clustermust also be specified. This parameter is not supported for relationships with non-ONTAP destination endpoints. -destination-volume <volume name>- Destination Volume }-
Specifies the destination volume of the SnapMirror relationship. If this parameter is specified, parameters
-destination-vserverand for relationships with"Relationship Capability"of"Pre 8.2",-destination-clustermust also be specified. This parameter is not supported for relationships with non-ONTAP destination endpoints. [-s, -source-snapshot <text>]- Source Snapshot-
This optional parameter specifies a snapshot to transfer. The default behavior for a data protection relationship with a read-write source is that ONTAP creates a new snapshot and uses it as the basis for determining what data is replicated; with this option, the specified snapshot will be used instead. The default behavior for an extended data protection relationship depends on the relationship's policy type. For a data protection relationship, the specified snapshot must be newer than the latest common snapshot. For an extended data protection relationship, the specified snapshot can be newer or older than the common snapshot. This parameter is not supported for relationships with
"Relationship Capability"of"Pre 8.2". [-type <snapmirrorType>]- Snapmirror Relationship Type-
Specifies the type of SnapMirror relationship if a relationship is implicitly created. This parameter is the same as the one used in the snapmirror create command.
[-policy <sm_policy>]- SnapMirror Policy-
This optional parameter designates the name of the SnapMirror policy which is associated with the SnapMirror relationship. If you do not designate a policy, the current policy will be retained. This parameter is not applicable to relationships with
"Relationship Capability"of"Pre 8.2".You define and name a policy using the snapmirror policy create command. [-f, -force <true>]- Force-
If this parameter is specified, the command proceeds without prompting for confirmation.
[-k, -throttle <throttleType>]- Throttle (KB/sec)-
This optional parameter limits the network bandwidth used for the resync transfer. It sets the maximum rate (in Kbytes/sec) at which data can be transferred during the operation. If this parameter is not specified, the throttle value configured for the relationship with the snapmirror create or snapmirror modify command will be used. To fully use the network bandwidth available, set the throttle value to
unlimitedor0. The minimum throttle value is four Kbytes/sec, so if you specify a throttle value between1and4, it will be treated as if you specified4. For FlexGroup and Application Consistency Group relationships, the throttle value is applied individually to each constituent relationship. For relationships with a policy of typestrict-sync-mirrororsync-mirror, the throttle value is applicable only for the asynchronous transfers of the resync operation. The-throttleparameter does not affect load-sharing transfers and transfers for other relationships with"Relationship Capability"of"Pre 8.2"confined to a single cluster. [-transfer-priority {low|normal}]- Transfer Priority-
This optional parameter specifies the priority at which the transfer runs. The default value for this parameter is the value in the SnapMirror policy associated with this relationship. This parameter is not applicable to relationships with a
"Relationship Capability"of"Pre 8.2". [-preserve <true>]- Preserve-
This parameter is only supported for extended data protection (XDP) relationships with policies of type
vault, andmirror-vault. It is not supported for relationships with a policy of typeasync-mirrorand data protection and load-sharing relationships. This parameter is not supported for relationships with non-ONTAP endpoints. It is not supported for relationships with a policy of typestrict-sync-mirrorandsync-mirror. When specified, it changes the behavior of thesnapmirror resynccommand to preserve snapshots on the destination volume that are newer than the latest common snapshot. This parameter is not supported for relationships with"Relationship Capability"of"Pre 8.2". [-quick-resync <true>]- Quick Resync-
This parameter is only supported for extended data protection (XDP) relationships. This parameter is not supported for relationships with non-ONTAP endpoints. It is not supported for relationships with a policy of type
strict-sync-mirrorandsync-mirror. Specifying this optional parameter reduces the resync time because the resync does not incur storage efficiency overhead before the transfer of new data. Specifying this parameter is recommended if the source of the resync does not have volume efficiency enabled or if reducing resync time is more important than preserving all possible storage efficiency. When this parameter is specified, resync does not preserve the storage efficiency of the new data with existing data over the wire and on the destination. [-cg-item-mappings {<source volume>:@<destination volume>|<source item path>:@<destination item path>}]- Consistency Group Item Mappings-
This optional parameter specifies a list of the consistency group (CG) item mappings. It is considered only if the supplied source and destination path values denote valid CG paths. For CG level relationships, this parameter must be specified. The value for this parameter must contain mappings of one or more pairs of constituent source and destination volumes of the form
srcvol1:@dstvol1,…. [-is-auto-expand-enabled {true|false}]- Is Auto Expand Enabled-
This optional parameter specifies whether or not a FlexGroup SnapMirror relationship and its destination FlexGroup should be auto-expanded if the source FlexGroup is expanded. This parameter is supported only for FlexGroup SnapMirror relationships. If this resync is creating a new SnapMirror relationship, the default value is true. If it is not creating a new relationship, if a value is specified, it must match the current value for the existing relationship. If the parameter is not specified, the existing value will be retained.
[-backoff-level {high|medium|none}]- SM Backoff Level due to Client Ops-
This optional parameter specifies the SnapMirror backoff level due to client ops. This parameter is supported only for FlexVol SnapMirror relationships. The default value is
high. [-w, -foreground <true>]- Foreground Process-
This specifies whether the operation runs as a foreground process. If this parameter is specified, the default setting is
true(the operation runs in the foreground). When set totrue, the command will not return until the process completes. This parameter is only applicable to relationships with"Relationship Capability"of"Pre 8.2".
To resynchronize the SnapMirror active sync relationship with the source Consistency Group cg_src in Vserver vs1.example.com and the destination Consistency Group cg_dst in Vserver vs2.example.com , type the following command from the destination cluster:
destination::> snapmirror resync -destination-path
vs2.example.com:/cg/cg_dst
To resynchronize an SnapMirror active sync relationship with the following attributes:
It is between the source Consistency Group
cg_srcin Vservervs1.example.com, and the destination Consistency Groupcg_dstin Vservervs2.example.com. -
It has item mappings between volumes
srcvol1andsrcvol2and volumesdstvol1anddstvol2.
Type the following command from the destination cluster:
vs2.example.com:/cg/cg_dst -source-path
vs1.example.com:/cg/cg_src
-cg-item-mappings srcvol1:@dstvol1,srcvol2:@dstvol2
To reestablish mirroring to the destination Application Consistency Group app_cg_dst in Vserver vs2.example.com that has been previously broken off with the snapmirror break command, type the following command:
vs2.example.com::> snapmirror resync -destination-path
vs2.example.com:/cg/app_cg_dst
