storage aggregate object-store config rename
Rename an existing object store configuration
The `storage aggregate object-store config rename` command is used to rename an exiting object store configuration.
-object-store-name <text>- Object Store Configuration Name-
This parameter identifies an existing object store configuration.
-new-object-store-name <text>- Object Store Configuration New Name-
This parameter specifies the new object store configuration name.
The following example renames an object store configuration from my-store to ms1:
cluster1::>storage aggregate object-store config rename -object-store-name my-store -new-object-store-name ms1
