ONTAP commands
storage stackmon repair show
Display repairs that will be made to stackmon if \"storage stackmon repair run\" is executed
The storage stackmon repair show command diagnoses stackmon reconciliation failures and displays the repairs that will be made if storage stackmon repair run is executed:
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-shelf-uid <integer>] - Shelf UID (privilege: advanced)
Displays the stackmon repairs for the specified shelf. Use storage shelf show -fields shelf-uuid to find the shelf-uid.
[-old-stack-id <integer>] - Old Stack ID (privilege: advanced)
Displays the stackmon repairs with the specified current stack-id.
[-new-stack-id <integer>] - New Stack ID (privilege: advanced)
Displays the stackmon repairs with the specified new stack-id.
[-skip-check-stackmon-state <true>] - Skip Check for Stackmon State (privilege: advanced)
This parameter allows the command to be executed when stackmon is still running.
The following example displays the stackmon repairs:
cluster 1::*> storage stackmon repair show
Shelf                Old Stack New Stack
  123370712932616784         1         1
  292812051842665040         3         1
 4342319975102154064         2         2
 4558492757215937872         2         2
 5350844816656434512         1         1
 9274403680772754000         1         1
 9346461274810681936         2         2
10786768730639108688         2         2
8 entries were displayed.
