ONTAP commands
system controller bezel-led show
Display the state of the bezel LED logo (lit or unlit)
The system controller bezel-led show command shows the current illumination state of the bezel LED logo (lit or unlit).
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
The node whose bezel LED logo illumination state is being shown.
[-state {off|on|disconnected|bezel-switch|unknown}] - Bezel LED Logo State
The bezel LED logo illumination state of the node.
The following example lists the current illumination state of the bezel LED logo:
cluster1::> system controller bezel-led show
Node            Bezel LED Logo State
node1           off
node2           off
