ONTAP commands
system ha interconnect config show
Display the high-availability interconnect configuration information
The system ha interconnect config show command displays the high-availability interconnect device basic configuration information.
[-fields <fieldname>,…​]
If you specify the -fields <fieldname>,…​ parameter, the command displays only the fields that you specify.
| [-instance ] (privilege: advanced) }
Use this parameter to display all the fields from all nodes in cluster.
[-node {<nodename>|local}] - Node (privilege: advanced)
Use this parameter to display all the fields from the specified node in the cluster.
[-transport <text>] - Interconnect Type (privilege: advanced)
Selects the nodes that match this HA interconnect transport type.
[-local-sysid <integer>] - Local System ID (privilege: advanced)
Selects the nodes that match this local system unique identifier.
[-partner-sysid <integer>] - Partner System ID (privilege: advanced)
Selects the nodes that match this partner system unique identifier.
[-initiator {local|partner}] - Connection Initiator (privilege: advanced)
Selects the nodes that match this parameter value. The value is the initiator of the connection request.
[-port-name <text>,…​] - Port (privilege: advanced)
Selects the nodes that match this port name.
[-ipaddress <text>,…​] - IP Address (privilege: advanced)
Selects the nodes that match this IP address.
[-interface {backplane|external}] - Interface (privilege: advanced)
Selects the nodes that match this parameter value. external means the HA interconnect links between partner nodes are connected externally. backplane means the HA interconnect links between partner nodes are connected over the backplane.
The following example displays the HA interconnect configuration information on FAS8000 series nodes in the cluster:
cluster1::*> system ha interconnect config show
Node: ic-f8040-01
          Interconnect Type: Infiniband (Mellanox ConnectX)
            Local System ID: 536875713
          Partner System ID: 536875678
       Connection Initiator: local
                  Interface: backplane
Port   IP Address         Flags
ib0a  192.0.3.236        0x0
ib0b  192.0.3.237        0x0
Node: ic-f8040-02
            Local System ID: 536875678
          Partner System ID: 536875713
       Connection Initiator: partner
ib0a  192.0.3.96         0x0
ib0b  192.0.3.97         0x0
2 entries were displayed.
The following example displays the HA interconnect configuration information on FAS2500 series nodes in the cluster:
Node: ic-f2554-03
          Interconnect Type: Infiniband (Mellanox Sinai)
            Local System ID: 1781036608
          Partner System ID: 1780360209
ib0a  ib0a               -
Node: ic-f2554-04
            Local System ID: 1780360209
          Partner System ID: 1781036608
ib0a  ib0a               -
