volume snapshot show-delta
Computes delta between two Snapshot copies
The volume snapshot show-delta command returns the number of bytes that changed between two snapshots or a snapshot and the active filesystem. This is calculated from the number of blocks that differ multiplied by the block size. The command also shows the time elapsed between the snapshots in seconds.
Queries that use query operators (* , | , etc.) are disabled for this command to avoid performance degradation for client requests.
- -vserver <vserver name>- Vserver Name
This specifies the Vserver on which the volume is located.
- -volume <volume name>- Volume Name
This specifies the volume for which the delta is to be calculated.
- -snapshot1 <snapshot name>- First Snapshot Name
This specifies the first snapshot for the comparison.
- [-snapshot2 <snapshot name>]- Second Snapshot Name
This specifies the second snapshot for the comparison. If the field is not specified, it is assumed to be the Active File System.
The following example shows the bytes changed and the time separating the two snapshots:
cluster1::> volume snapshot show-delta -vserver vs0 -volume vol2 -snapshot1 one -snapshot2 two A total of 139264 bytes (34 blocks) are different. Elapsed time between the snapshots: 1s.
 PDFs
PDFs
