ONTAP commands
vserver consistency-group delete
Delete an existing consistency group
The vserver consistency-group delete command can be used to delete a consistency group.
-vserver <Vserver Name> - Vserver Name
This parameter specifies the Vserver that contains the consistency group that is to be deleted.
-consistency-group <text> - Consistency Group Name
This parameter specifies the consistency group that is to be deleted.
[-parent-consistency-group <text>] - Parent Consistency Group Name
This parameter specifies the parent consistency group of the consistency group that is to be deleted.
The following command deletes the consistency group parentCG in Vserver vs0.
cluster1::> vserver consistency-group delete -vserver vs0 -consistency-group parentCG -parent-consistency-group -
        (vserver consistency-group delete)
Warning: Are you sure you want to delete consistency group "parentCG" in
         Vserver "vs0" ? {y|n}: y
[Job 174] Job succeeded: Success
1 entry was deleted.
