vserver consistency-group snapshot delete
Delete an existing consistency group Snapshot Copy
The vserver consistency-group snapshot delete command deletes a snapshot of a specified consistency group.
- -vserver <Vserver Name>- Vserver Name
This parameter specifies the Vserver that contains the consistency group on which the snapshot is to be deleted.
- -consistency-group <text>- Consistency Group Name
This parameter specifies the consistency group where a snapshot is to be deleted.
- [-parent-consistency-group <text>]- Parent Consistency Group Name
This parameter specifies the parent consistency group where a snapshot is to be deleted.
- -snapshot <snapshot name>- Snapshot Copy Name
This parameter specifies the name of the snapshot that is to be deleted.
The following example deletes a snapshot named snap1 on a child consistency group named cg1 in parent consistency group parentCg on a Vserver named vs0.
cluster1::> vserver consistency-group snapshot delete -vserver vs0 -consistency-group cg1 -parent-consistency-group parentCg -snapshot snap1
    (vserver consistency-group snapshot delete)
Warning: Deleting a snapshot permanently removes data that is stored only in that snapshot. Are you sure you want to delete snapshot
         "snap1" for consistency group "cg1" in Vserver "vs0" ? {y|n}: y
 PDFs
PDFs
