vserver migrate show
Display status of migrating Vservers
This command displays information about the migrating vserver.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-migrate-status-details ]
If this parameter is specified, the command displays the following information about Vserver migrate operation. -
Vserver
Migrate status
Status details
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver name>]- Vserver Name
Name of the Vserver which is migrating.
- [-vserver-uuid <UUID>]- Vserver UUID
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver UUID.
- [-destination-cluster <Cluster name>]- Destination Cluster Name
If this parameter is specified, the command displays Vserver migrate information that matches the specified destination cluster.
- [-source-cluster <Cluster name>]- Source Cluster Name
If this parameter is specified, the command displays Vserver migrate information that matches the specified source cluster.
- [-migrate-status {precheck-started|transferring|ready-for-cutover|cutover-triggered|cutover-started|cutover-complete|migrate-paused|migrate-complete|migrate-complete-with-warnings|migrate-failed|cleanup|cleanup-failed|manual-cleanup|destination-cleaned-up|migrate-pausing|cleanup-pausing|post-cutover|post-cutover-failed|ready-for-source-cleanup|setup-configuration|setup-configuration-failed|migrate-pause-failed|migrate-aborting|migrate-abort-failed|migrate-aborted}]- Vserver migrate status
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate status.
- [-start-time <MM/DD/YYYY HH:MM:SS>]- Migrate start time
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate start time.
- [-end-time <MM/DD/YYYY HH:MM:SS>]- Migrate operation finish time
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate end time.
- [-last-pause-time <MM/DD/YYYY HH:MM:SS>]- Last migrate pause time
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate last paused time.
- [-last-resume-time <MM/DD/YYYY HH:MM:SS>]- Last migrate resume time
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate last resume time.
- [-last-restart-time <MM/DD/YYYY HH:MM:SS>]- Last migrate restart time
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate last rollback time.
- [-cutover-precommit-start-time <MM/DD/YYYY HH:MM:SS>]- Cutover precommit start time
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate cutover trigger time.
- [-cutover-commit-start-time <MM/DD/YYYY HH:MM:SS>]- Cutover commit start time
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate cutover start time.
- [-cutover-complete-time <MM/DD/YYYY HH:MM:SS>]- Cutover complete time
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate cutover completion time.
- [-restart-count <integer>]- Restart Count
If this parameter is specified, the command displays Vserver migrate information that matches the specified rollback count.
- [-status-details <text>,…]- Errors and Warnings During Migrate
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate status details.
- [-ipspace <IPspace>]- Destination cluster IPspace Name for vserver
If this parameter is specified, the command displays Vserver migrate information that matches the specified ipspace.
- [-aggr-list <aggregate name>,…]- Aggregate list for creating the volumes
If this parameter is specified, the command displays Vserver migrate information that matches the specified aggregate list that are assigned for Vserver to use.
- [-migrate-vserver-type {migrate-source|migrate-destination}]- Identify if the Vserver is migrate source or destination
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver migrate type.
- [-owning-node <nodename>]- Name of node on which migrate is orchestrated
If this parameter is specified, the command displays Vserver migrate information that matches the specified node that owns Vserver migrate.
- [-stream-uuid <UUID>]- Stream Uuid
If this parameter is specified, the command displays Vserver migrate information that matches the specified stream UUID.
- [-is-past-point-of-no-return {true|false}]- Indicate point of no return for migrate
If this parameter is specified, the command displays Vserver migrate information that matches the specified past point of no return flag.
- [-last-failed-migrate-status {precheck-started|transferring|ready-for-cutover|cutover-triggered|cutover-started|cutover-complete|migrate-paused|migrate-complete|migrate-complete-with-warnings|migrate-failed|cleanup|cleanup-failed|manual-cleanup|destination-cleaned-up|migrate-pausing|cleanup-pausing|post-cutover|post-cutover-failed|ready-for-source-cleanup|setup-configuration|setup-configuration-failed|migrate-pause-failed|migrate-aborting|migrate-abort-failed|migrate-aborted}]- Migrate status when the migrate aborted or failed
If this parameter is specified, the command displays Vserver migrate information that matches the specified last failed Vserver migrate status.
- [-current-migrate-operation {none|start|resume|pause|cleanup|cutover|abort}]- Current Migrate operation
If this parameter is specified, the command displays Vserver migrate information that matches the specified current Vserver migrate operation.
- [-last-migrate-operation {none|start|resume|pause|cleanup|cutover|abort}]- Last Migrate operation
If this parameter is specified, the command displays Vserver migrate information that matches the specified last Vserver migrate operation.
- [-local-vserver-id <integer>]- Vserver ID
If this parameter is specified, the command displays Vserver migrate information that matches the specified local Vserver ID.
- [-group-id <integer>]- Group ID
If this parameter is specified, the command displays Vserver migrate information that matches the specified group ID.
- [-partner-vserver-id <integer>]- Partner Vserver ID
If this parameter is specified, the command displays Vserver migrate information that matches the specified Vserver ID of a partner node.
- [-partner-group-id <integer>]- Partner group ID
If this parameter is specified, the command displays Vserver migrate information that matches the specified group ID of a partner node.
- [-auto-cutover {true|false}]- Automatic cutover
If this parameter is specified, the command displays Vserver migrate information that matches the specified auto cutover flag.
- [-skip-performance-check {true|false}]- Skip checking iops requirement of volume on destination aggregates
If this parameter is specified, the command displays Vserver migrate information that matches the specified skip performance flag.
- [-migration-uuid <UUID>]- Migration UUID
If this parameter is specified, the command displays Vserver migrate information that matches the specified migration UUID.
- [-migration-failures <SmdbError>,…]- List of migration failures
If this parameter is specified, the command displays Vserver migrate information that matches the specified migration failures.
- [-client-outage-window <integer>]- Window duration during cutover when clients are not served
If this parameter is specified, the command displays Vserver migrate information that matches the specified client outage window.
- [-auto-source-cleanup {true|false}]- Automatic source cleanup (privilege: advanced)
If this parameter is specified, the command displays Vserver migrate information that matches the specified auto source cleanup flag.
- [-throttle <throttleType>]- Throttle for Migrate Transfers(Kbs)
If this parameter is specified, the command displays Vserver migrate information that matches the specified throttle value.
cluster1::> vserver migrate show -vserver test
 PDFs
PDFs
