vserver nfs storepool blocked-client flush
Flush cached blocked client entries on the specified node
The vserver nfs storepool blocked-client flush
command flushes the storepool blocked client cache which allows the previously blocked specified clients to reconnect.
Node on which storepool blocked client cache is present
Client ip address
-node <nodename>
- Node (privilege: advanced)-
If this parameter is specified, the command is used to flush the storepool blocked client cache only in the specified node.
[-client-ip <IP Address>]
- Client IP Address (privilege: advanced)-
If this parameter is specified, the command is used to only flush the storepool blocked client cache associated with specified client IP.
The following example flushes all NFSv4 storepool blocked client caches present on node1.
cluster1::*> vserver nfs storepool blocked-client flush -node node1 Number of NFSv4.x blocked clients flushed on node "node1": 0. cluster1::*>
