ONTAP commands
vserver vscan scanner-pool privileged-users show
Display list of privileged users
The vserver vscan scanner-pool privileged-users show command displays the list of privileged users of the Vscan scanner pools belonging to the Vserver. If you do not specify any parameters, the command displays the following information about the scanner pools:
  • Vserver name
  • Scanner pool
  • List of privileged users
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
If you specify this parameter, the command displays information only about the scanner pools for the specified Vserver.
[-scanner-pool <Scanner pool>] - Scanner Pool
If you specify this parameter, the command displays information only for the specified scanner pool.
[-privileged-users <Privileged user>,…​] - List of Privileged Users
If you specify this parameter, the command displays information only about the scanner pools that have the specified privileged user or users.
The following example displays the list of privileged users of all scanner pools.
cluster1::> vserver vscan scanner-pool privileged-users show
Vserver         Scanner Pool      Privileged Users
Cluster         clus              cifs\u5
vs1             new               cifs\u7
vs1             clus              cifs\u5
vs1             p1                cifs\u1, cifs\u2
vs2             clus              cifs\u5
vs2             p2                cifs\u2
6 entries were displayed.
