metrocluster modify
Modify MetroCluster configuration options
The metrocluster modify command modifies MetroCluster parameters for nodes in the MetroCluster configuration.
-auto-switchover-failure-domain <MetroCluster AUSO Failure Domain>- Cluster Level AUSO Option -
This parameter specifies the configuration of automatic switchover.
The parameter values are:
auso-on-cluster-disaster - triggers an unplanned switchover if all nodes in a DR cluster are down.
auso-on-dr-group-disaster - triggers an unplanned switchover if both nodes of a DR group are down.
auso-disabled - automatic switchover is disabled.
A change to the parameter affects only the local cluster where the
metrocluster modifycommand is used. -
-enable-unmirrored-aggr-deployment {true|false}- Enable or Disable Unmirrored Aggregate Deployment -
Enable or disable unmirrored aggregates deployment
-is-encryption-enabled {true|false}- Is Encryption Enabled -
This parameter is used to enable or disable NVLog and Storage data encryption in MetroCluster over IP configuration.
-dr-group-id <integer>- DR Group ID-
This parameter identifies the DR group where encryption is being enabled or disabled.
[-allow-auto-forced-switchover {true|false}]- Allow Automatic Forced Switchover (privilege: advanced) -
This parameter is used to enable automatic forced switchover on node failures. The
allow-auto-forced-switchoverparameter is only supported on a MetroCluster over IP configuration. Refer to the MetroCluster documentation for risks and limitations of this feature.All nodes in a MetroCluster configuration must have this option enabled to enable automatic forced switchover on failure.
-node-name {<nodename>|local}- Node to Change the Option On } -
This parameter is used to specify the node in the cluster for which the parameter needs to be modified.
[-automatic-switchover-onfailure <true>]- Node Level AUSO Option (privilege: advanced) }-
This parameter is used to enable automatic switchover on node failures. The
automatic-switchover-onfailureparameter is not supported on a MetroCluster over IP configuration.All nodes in a MetroCluster configuration must have this option enabled to enable automatic switchover on failure.
The following example shows the output of MetroCluster modification done on a node:
clusA::*> metrocluster modify -node-name clusA-01 -node-object-limit on [Job 168] Job succeeded: Modify is successful clusA::*> metrocluster modify -node-name clusA-01 -automatic-switchover-onfailure false [Job 308] Job succeeded: Modify is successful clusA::> metrocluster modify -auto-switchover-failure-domain auso-on-cluster-disaster [Job 308] Job succeeded: Modify is successful clusA::> metrocluster modify -is-encryption-enabled true -dr-group-id 1 [Job 206] Job succeeded: Modify is successful
