Command reference
qos policy-group delete
Delete an existing QoS Policy Group
The qos policy-group delete command deletes a policy group from a cluster. You cannot delete a policy group if a qos workload associated with storage object is assigned to it unless you use "-force". Using "-force" will delete all the qos workloads for storage objects associated with the specified policy groups .
You can only delete user-defined policy groups. You cannot delete preset policy groups.
-policy-group <text> - Policy Group Name
Specifies the name of the policy group that you want to delete.
[-force <true>] - Force Delete Workloads for the QoS Policy Group (privilege: advanced)
Specifies whether to delete a policy group along with any underlying workloads.
cluster1::> qos policy-group delete p1
Deletes the "p1" policy group.
cluster1::> qos policy-group delete p1 -force
Deletes the "p1" policy group along with any underlying qos workloads.
