Command reference
security anti-ransomware show
Display Anti-ransomware Package Version of the Node
The security anti-ransomware show command displays the Anti-ransomware version of a node.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node Name
If this parameter is specified, the command displays the Anti-ransomware version of specified node.
[-version <text>] - Anti-Ransomware Version
If this parameter is specified, the command displays node with the specified Anti-ransomware version.
The following example shows a sample output for this command:
C1_cluster::*> security anti-ransomware show-version
Node                 Version
sti221-vsim-sr049g   1.0
sti221-vsim-sr049h   1.0
2 entries were displayed.
