Command reference
security dynamic-authorization group show
Display Dynamic Authorization groups
The security dynamic-authorization group show command displays information about the dynamic authorization groups.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
Selects dynamic-authorization groups for this Vserver.
[-name <text>] - Group Name
Selects dynamic-authorization groups that match this group name.
[-excluded-usernames <text>,…​] - List of Excluded Users
Selects the dynamic-authorization groups that match the specified excluded username.
[-comment <text>] - Comment
Selects the dynamic-authorization groups that match this comment.
The example below displays dynamic authorization group information for the Vserver vs1 .
cluster1::> security dynamic-authorization group show -vserver vs1
               Vserver: vs1
            Group Name: NETAPP_ENG
List of Excluded Users: user1, user2, user12
               Comment: -
