Command reference
security saml-sp default-metadata create
Create SAML Default Metadata
The security saml-sp default-metadata create command configures ONTAP with Security Assertion Markup Language (SAML) Service Provider (SP) default metadata for single sign-on authentication. The default metadata is used while configuring the Identity Provider (IDP).
Note This restarts the web server. Any HTTP/S connections that are active will be disrupted.
[-sp-host <Remote InetAddress>] - SAML Service Provider Host
This specifies the SAML service provider host IP address.
{ -cert-ca <text> - Server Certificate Issuing CA
This specifies the service provider's certificate issuing CA.
-cert-serial <text> - Server Certificate Serial Number
This specifies the service provider's certificate's serial number.
| [-cert-common-name <FQDN or Custom Common Name>] - Server Certificate Common Name }
This specifies the service provider certificate's common name.
[-foreground {true|false}] - Foreground Process
When this parameter is set to false the command runs in the background as a job. The default is true , which causes the command to return after the operation completes.
The following example configures ONTAP with SAML default metadata:
cluster1::> security saml-sp default-metadata create -sp-host 1.1.1.1
    [Job 9] Job succeeded: Access the SAML SP default metadata using the URL:
    https://1.1.1.1/saml-sp/Metadata
    cluster1::>
