security saml-sp default-metadata create
Create SAML Default Metadata
The security saml-sp default-metadata create command configures ONTAP with Security Assertion Markup Language (SAML) Service Provider (SP) default metadata for single sign-on authentication. The default metadata is used while configuring the Identity Provider (IDP).
This restarts the web server. Any HTTP/S connections that are active will be disrupted. |
[-sp-host <Remote InetAddress>]- SAML Service Provider Host-
This specifies the SAML service provider host IP address.
-cert-ca <text>- Server Certificate Issuing CA -
This specifies the service provider's certificate issuing CA.
-cert-serial <text>- Server Certificate Serial Number-
This specifies the service provider's certificate's serial number.
[-cert-common-name <FQDN or Custom Common Name>]- Server Certificate Common Name } -
This specifies the service provider certificate's common name.
[-foreground {true|false}]- Foreground Process-
When this parameter is set to
falsethe command runs in the background as a job. The default istrue, which causes the command to return after the operation completes.
The following example configures ONTAP with SAML default metadata:
cluster1::> security saml-sp default-metadata create -sp-host 1.1.1.1
[Job 9] Job succeeded: Access the SAML SP default metadata using the URL:
https://1.1.1.1/saml-sp/Metadata
cluster1::>
