Command reference
volume analytics cluster-config modify
Modify the file system analytics cluster configuration
The volume analytics cluster-config modify command modifies the cluster level file system analytics configuration.
[-is-enabled-by-default {true|false}] - Is Enabled by Default
This parameter controls whether file system analytics is enabled by default on all newly created Vservers. The default value is true .
The following example modifies the cluster level file system analytics configuration:
cluster::*> volume analytics cluster-config modify -is-enabled-by-default true
