volume analytics cluster-config modify
Modify the file system analytics cluster configuration
The volume analytics cluster-config modify command modifies the cluster level file system analytics configuration.
[-is-enabled-by-default {true|false}]- Is Enabled by Default-
This parameter controls whether file system analytics is enabled by default on all newly created Vservers. The default value is
true.
The following example modifies the cluster level file system analytics configuration:
cluster::*> volume analytics cluster-config modify -is-enabled-by-default true
