Command reference
cluster log-forwarding create
Create a log forwarding destination
The cluster log-forwarding create command creates log forwarding destinations for remote logging.
-destination <Remote InetAddress> - Destination Host
Host name or IPv4 or IPv6 address of the server to forward the logs to.
[-port <integer>] - Destination Port
The port that the destination server listen on.
[-protocol {udp-unencrypted|tcp-unencrypted|tcp-encrypted}] - Log Forwarding Protocol
The protocols are used for sending messages to the destination. The protocols can be one of the following values:
  • udp-unencrypted - User Datagram Protocol with no security
  • tcp-unencrypted - Transmission Control Protocol with no security
  • tcp-encrypted - Transmission Control Protocol with Transport Layer Security (TLS)
[-ipspace <IPspace>] - IPspace of Destination
The IPspace of the destination server.
[-verify-server {true|false}] - Verify Destination Server Identity
When this parameter is set to true , the identity of the log forwarding destination is verified by validating its certificate. The value can be set to true only when the tcp-encrypted value is selected in the protocol field. When this value is true the remote server might be validated by OCSP. The OCSP validation for cluster logs is controlled with the security config ocsp enable -app audit_log and security config ocsp disable -app audit_log .
[-facility <Syslog Facility>] - Syslog Facility
The Syslog facility to use for the forwarded logs.
[-force <true>] - Skip the Connectivity Test
Normally, the cluster log-forwarding create command checks that the destination is reachable via an ICMP ping, and fails if it is not reachable. Setting this value to true bypasses the ping check so that the destination can be configured when it is unreachable.
[-message-format {legacy-netapp|rfc-5424}] - Syslog Message Format
Use this parameter to specify the message format to be used for Syslog messages.
The message-format can be one of the following values:
  • legacy-netapp - A variation of the RFC-3164 Syslog format (format: <PRIVAL>TIMESTAMP HOSTNAME: MSG)
  • rfc-5424 - Syslog format as per RFC-5424 (format: <PRIVAL>VERSION TIMESTAMP HOSTNAME: MSG)
Refer to the respective RFCs for detailed information regarding the Syslog message formats.
The default message format is legacy-netapp .
[-timestamp-format-override {no-override|rfc-3164|iso-8601-utc|iso-8601-local-time}] - Syslog Timestamp Format Override
Use this parameter to override the default timestamp format (based on the message-format parameter) used for Syslog messages.
The timestamp-format-override can be one of the following values:
  • no-override - Timestamp format based on the message-format parameter (rfc-3164 if the message format is legacy-netapp , iso-8601-local-time if message format is rfc-5424 )
  • rfc-3164 - Timestamp format as per RFC-3164 (format: Mmm dd hh:mm:ss)
  • iso-8601-utc - Timestamp format as per ISO-8601 in UTC (format: YYYY-MM-DDThh:mm:ssZ)
  • iso-8601-local-time - Timestamp format as per ISO-8601 in local time (format: YYYY-MM-DDThh:mm:ss+/-hh:mm)
The default value is no-override . When this parameter is modified, its value persists even when message-format is updated. +
[-hostname-format-override {no-override|fqdn|hostname-only}] - Syslog Hostname Format Override
Use this parameter to override the default hostname format (based on the message-format parameter) used for Syslog messages.
The hostname-format-override can be one of the following values:
  • no-override - Hostname format based on the message-format parameter (fqdn if the message format is rfc-5424 , hostname-only if message format is legacy-netapp )
  • fqdn - Fully Qualified Domain Name (e.g., myhost.example.com)
  • hostname-only - Hostname only, without the domain name (e.g., myhost)
This example causes audit logs to be forwarded to a server at address 192.168.0.1, port 514 with USER facility.
cluster1::> cluster log-forwarding create -destination 192.168.0.1 -port 514 -facility user
