Command reference
debug hwpmc show
Display HWPMC profiles
The debug hwpmc show command displays a list of the current Hardware Performance Monitoring Counter profiles along with the state of each one.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-node {<nodename>|local}] - Node Name (privilege: advanced)
This parameter selects the node from which the profiles are displayed.
[-name <text>] - Name of the HWPMC Profile (privilege: advanced)
This parameter specifies the name of the profile.
[-date <MM/DD/YYYY HH:MM:SS>] - Date of the HWPMC Profile (privilege: advanced)
This parameter filters the results to display profiles for a specific date or a date range.
[-status <State of HWPMC Profiles>] - Current Status of HWPMC Profile (privilege: advanced)
This parameter specifies the current state of the profile. The possible states are:
  • running - Collecting hardware profiling data. The amount of time in this state is directly related to the -duration parameter used when creating the HWPMC profile.
  • processing - The hardware profiling data is being processed. This typically takes several minutes to complete, depending on the amount of data collected in the running state."
  • complete - The profile is complete.
  • failed - Creation of the profile failed. Use debug hwpmc show -instance for details.
[-status-message <text>] - Current Status Message (privilege: advanced)
This parameter displays extended status messages associated with each profile.
[-counter <text>] - HWPMC Event Specification (privilege: advanced)
This parameter specifies one or more performance counters to be displayed.
[-process <text>] - Profile Specific Process (privilege: advanced)
This parameter filters the output to show profiles associated with a specific process or process identifier.
The following example displays information about the profiles on a node:
cluster1::> debug hwpmc show -node node1
Node                 Profile Name              Status
node1                2023_06_06-08_53_44_UTC   collecting
node1                2023_06_06-08_54_53_UTC   complete
