debug hwpmc show
Display HWPMC profiles
The debug hwpmc show command displays a list of the current Hardware Performance Monitoring Counter profiles along with the state of each one.
[-fields <fieldname>,…]-
If you specify the
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node Name (privilege: advanced)-
This parameter selects the node from which the profiles are displayed.
[-name <text>]- Name of the HWPMC Profile (privilege: advanced)-
This parameter specifies the name of the profile.
[-date <MM/DD/YYYY HH:MM:SS>]- Date of the HWPMC Profile (privilege: advanced)-
This parameter filters the results to display profiles for a specific date or a date range.
[-status <State of HWPMC Profiles>]- Current Status of HWPMC Profile (privilege: advanced)-
This parameter specifies the current state of the profile. The possible states are:
running - Collecting hardware profiling data. The amount of time in this state is directly related to the
-durationparameter used when creating the HWPMC profile. -
processing - The hardware profiling data is being processed. This typically takes several minutes to complete, depending on the amount of data collected in the
runningstate." -
complete - The profile is complete.
failed - Creation of the profile failed. Use
debug hwpmc show -instancefor details.
[-status-message <text>]- Current Status Message (privilege: advanced)-
This parameter displays extended status messages associated with each profile.
[-counter <text>]- HWPMC Event Specification (privilege: advanced)-
This parameter specifies one or more performance counters to be displayed.
[-process <text>]- Profile Specific Process (privilege: advanced)-
This parameter filters the output to show profiles associated with a specific process or process identifier.
The following example displays information about the profiles on a node:
cluster1::> debug hwpmc show -node node1 Node Profile Name Status -------------------- ------------------------- ----------- node1 2023_06_06-08_53_44_UTC collecting node1 2023_06_06-08_54_53_UTC complete
