security key-manager external barbican check
Show detailed status of the enabled Barbican KMS configurations
This command displays the Barbican Key Management Service (KMS) status.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
If this parameter is specified then the command displays only the Barbican status for the given node.
[-vserver <Vserver Name>]- Vserver Name-
If this parameter is specified then the command displays only the Barbican status for the given Vserver.
[-category <Categories for KMS using SVM KEK KM status check>]- Component-
If this parameter is specified then the command displays only the Barbican status for the given category.
Category Description -------- ----------- Status Status of the Barbican Key Management Service Details Detailed description of the status [-status <Status Check>]- Status-
If this parameter is specified then the command displays only the Barbican status entries matching the given status.
OK FAILED UNKNOWN [-detail <text>]- Status Details-
This field displays the detailed status message, if available.
The example below displays the status of all components of all Barbican configurations enabled on the node.
cluster-1::> security key-manager external barbican check
Vserver: vsSample1
Node: nodeSample
Category: service_reachability
Status: OK
Details: OK
Category: kms_wrapped_key_status
Status: OK
Details: OK
Vserver: vsSample2
Node: nodeSample
Status: OK
Details: OK
Status: OK
Details: OK
4 entries were displayed.
