security key-manager external barbican check
Show detailed status of the enabled Barbican KMS configurations
This command displays the Barbican Key Management Service (KMS) status.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
If this parameter is specified then the command displays only the Barbican status for the given node.
[-vserver <Vserver Name>]- Vserver Name-
If this parameter is specified then the command displays only the Barbican status for the given Vserver.
[-category <Categories for KMS using SVM KEK KM status check>]- Component-
If this parameter is specified then the command displays only the Barbican status for the given category.
Category Description
Status Status of the Barbican Key Management Service
Details Detailed description of the status
[-status <Status Check>]- Status-
If this parameter is specified then the command displays only the Barbican status entries matching the given status.
OK
FAILED
UNKNOWN
[-detail <text>]- Status Details-
This field displays the detailed status message, if available.
The example below displays the status of all components of all Barbican configurations enabled on the node.
cluster-1::> security key-manager external barbican check
Vserver: vsSample1
Node: nodeSample
Category: service_reachability
Status: OK
Details: OK
Category: kms_wrapped_key_status
Status: OK
Details: OK
Vserver: vsSample2
Node: nodeSample
Status: OK
Details: OK
Status: OK
Details: OK
4 entries were displayed.
