Command reference
security key-manager onboard enable
Enable the Onboard Key Manager
This command enables the Onboard Key Manager for the admin Vserver.
The following example enables the Onboard Key Manager for the admin Vserver cluster-1:
cluster-1::> security key-manager onboard enable
Enter the cluster-wide passphrase for the Onboard Key Manager:
Re-enter the cluster-wide passphrase:
After configuring the Onboard Key Manager, save the encrypted configuration data in a safe location so that you can use it if you need to perform a manual recovery operation. To view the data, use the "security key-manager onboard show-backup" command.
The following example enables the Onboard Key Manager for the admin Vserver cluster-1 with the cluster-wide passphrase "myPassphrase" on an external USB mass storage device:
cluster-1::> security key-manager onboard enable -vserver cluster-1 -okm-on-usb-enabled true -onboard-passphrase myPassphrase
