Command reference
vserver consistency-group snapshot start
Start a 2 phase Snapshot copy for a consistency group
The vserver consistency-group snapshot start command starts a 2-phase snapshot of a specified consistency group.
-vserver <Vserver Name> - Vserver Name
This parameter specifies the Vserver that contains the consistency group where the snapshot is to be started.
-consistency-group <text> - Consistency Group Name
This parameter specifies the consistency group where a snapshot is to be started.
-snapshot <snapshot name> - Snapshot Copy Name
This parameter specifies the name of the snapshot that is to be started.
[-parent-consistency-group <text>] - Parent Consistency Group Name
This parameter specifies the parent consistency group where a snapshot is to be started for a child consistency group.
[-consistency-type {crash|application}] - Consistency Type
This parameter optionally specifies the consistency level of a snapshot. The default value is crash .
[-comment <text>] - Comment
This parameter optionally specifies the comment associated with a snapshot.
[-snapmirror-label <text>] - Snapmirror Label
This parameter optionally specifies the label associated with a snapshot.
[-start-timeout <integer>] - Timeout for 2-phase snapshot
This parameter optionally specifies the timeout limit for the snapshot to be started. The default value is 7 seconds.
[-write-fence {true|false}] - Take write fence
This parameter specifies if a write fence is taken on the volumes in the consistency group while creating a snapshot.
The following example starts a 2-phase snapshot named snap2 on a child consistency group named childCg in parent consistency group parentCg on a Vserver named vs0. The snapshot has start-timeout set to "90".
cluster1::> vserver consistency-group snapshot start -vserver vs0 -consistency-group childCg -parent-consistency-group parentCg -snapshot snap2 -start-timeout 90
          (vserver consistency-group snapshot start)
