Command reference
debug nvme upgrade bypass-lif-state-check
Bypass the pre-takeover LIF state checks during ANDU
Before a node is taken over during an automated upgrade, there is a check to ensure each node with a mapped NVMe namespace has an online NVMe LIF. Without LIFs on each of these nodes, an outage is likely as nodes are restarted during the upgrade. If you do not care about an outage, or you know the current configuration will not cause one, use this command to bypass this check when the upgrade is resumed. This bypass is not persistent, and applies only to the node where the command is issued.
The following example disables the NVMe LIF checks during upgrade.
cluster1:*> debug nvme upgrade bypass-lif-state-check
