Command reference
lun igroup initiator upgrade missing-logins delete
Remove a missing login record
Missing initiator connections are likely to lead to a host outage during upgrade. If this is not a concern or it is known that a host connection is not required, the record of a missing login can be manually deleted to allow upgrade to proceed.
-vserver <Vserver Name> - Vserver (privilege: advanced)
Specifies the Vserver of the entry you want to delete.
-initiator <text> - Initiator (privilege: advanced)
Specifies the initiator of the entry you want to delete.
-lif <text> - LIF (privilege: advanced)
Specifies the LIF of the entry you want to delete.
The following example manually removes the record of a missing initiator login so that upgrade can proceed without this initiator connecting again.
cluster1::*> lun igroup initiator upgrade missing-logins delete -vserver vs1 -initiator iqn.1992-08.com.mv:def -lif iscsi4
