lun igroup initiator upgrade show-partially-connected
Display partially connected initiators
If upgrade proceeds with partially connected initiators, a host outage is likely. Each initiator should be connected to both nodes in each HA pair where the initiator is mapped to a LUN. This command displays connections that are missing and should be established before proceeding with an upgrade.
[-fields <fieldname>,…]-
If you specify the
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver (privilege: advanced)-
Selects the missing logins whose Vserver matches the specified value.
[-igroup <text>]- Igroup (privilege: advanced)-
Selects the missing logins whose igroup matches the specified value.
[-initiator <text>]- Initiator (privilege: advanced)-
Selects the missing logins whose initiator matches the specified value.
[-required-nodes {<nodename>|local}]- Required Nodes (privilege: advanced)-
Selects the missing logins whose required-nodes matches the specified value. The initiator should be logged in to all required nodes.
[-missing-nodes {<nodename>|local}]- Missing Nodes (privilege: advanced)-
Selects the missing logins whose missing-nodes matches the specified value. The initiator is not currently logged in to these nodes. If the initiator group is bound to a portset, the initiator needs to connect to a LIF in the portset on these nodes.
[-portset <text>]- Portset (privilege: advanced)-
Selects the missing logins whose portset matches the specified value. If the initiator group is bound to a portset, the logins must be to LIFs in the portset.
[-refresh-login-cache <true>]- Force Refresh (privilege: advanced)-
This command displays information based on a cache that is updated every 15 minutes. To force refresh the cache prior to displaying data, set this parameter to true.
The following example displays a partially connected initiator that needs to be connected to node2.
cluster1::*> lun igroup initiator upgrade show-partially-connected
Vserver Igroup Initiator Missing Nodes
vs1 igroup1 iqn.1992-08.com.mv:abc node2
