lun mapping modify
Modify a LUN map
This command modifies attributes of a LUN map.
-vserver <Vserver Name>- Vserver Name-
Specifies the Vserver that contains the LUN map you want to modify.
-path <path>- LUN Path -
Specifies the path of the LUN map that you want to modify. Examples of correct LUN paths:
/vol/vol1/lun1and/vol/vol1/qtree1/lun1 - |
-volume <volume name>- Volume Name -
Specifies the volume that contains the LUN map you want to modify.
-qtree <qtree name>- Qtree Name-
Specifies the qtree that contains the LUN map you want to modify.
-lun <text>- LUN Name }-
Specifies the LUN name of the LUN map that you want to modify.
-g, -igroup <text>- Igroup Name-
Specifies the igroup of the LUN map that you want to modify.
[-replicated {true|false}]- Replicated-
LUN maps are replicated when the initiator group is replicated and the mapped LUN is a member of a SnapMirror Synchronous relationship. When these conditions are met, this field defaults to true. When these conditions are not met, this field is reported as unset. When set to false, the LUN map on the remote cluster is deleted. When set to true, the LUN map on the remote cluster is created.
