Command reference
network options cluster-network-overlay-enabled show
Display cluster network overlay enabled option
This command displays the cluster-network-overlay-enabled for the cluster.
cluster1::*> network options cluster-network-overlay-enabled show
            Cluster Network Overlay Enabled: false
