security anti-ransomware auto-enable show
Show the anti-ransomware auto-enable settings for the cluster
The security anti-ransomware auto-enable show command retrieves the current anti-ransomware auto enablement values, including details about warm-up period and auto enablement setting for new volumes.
[-instance ]-
If you specify the
-instanceparameter, the command displays detailed information about all fields.
The following example shows a sample output for this command:
cluster1::> security anti-ransomware auto-enable show New Volume Auto-Enable: true Warm-Up Period Applicable: true Warm-Up Period Completed: false Warm-Up Period Duration: 12h Warm-Up Period Time Remaining: 10h
After warm-up period ends, warm-up related fields wont be displayed.
