security anti-ransomware volume entropy-stat show-encryption-percentage-histogram
Display the volume encryption percentage histogram
The security anti-ransomware volume entropy-stat show-encryption-percentage-histogram command displays the histogram for the volume.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name-
This parameter specifies the Vserver of the anti-ransomware enabled volume for which the entropy stats histogram need to be displayed. If this parameter is specified, the command displays entropy stats histogram only for the specified Vserver.
[-volume <volume name>]- Volume Name-
This parameter specifies the anti-ransomware enabled volume for which the entropy stats histogram need to be displayed. If this parameter is specified, the command displays entropy stats histogram only for the specified volume.
[-duration {real_time|evaluation_period|30days|90days|180days}]- Duration-
This parameter specifies the duration for which other details will be displayed
[-encryption-percent-range {0-5%|6-10%|11-15%|16-20%|21-25%|26-30%|31-35%|36-40%|41-45%|46-50%|51-55%|56-60%|61-65%|66-70%|71-75%|76-80%|81-100%}]- Encryption Percent Range-
This parameter specifies the range of encryption percentage for which additional details will be displayed.
[-count <integer>]- Count-
This parameter specifies the number of times data is written within the given encryption percentage range.
[-data-written {<integer>[KB|MB|GB|TB|PB]}]- Data Written-
This parameter specifies the amount of data written within the given encryption percentage range.
The following example displays the entropy stats histogram information of a volume.
cluster1::> security anti-ransomware volume entropy-stat show-encryption-percentage-histogram -vserver vs1 -volume volume_1
Encryption
Vserver volume Percent Range Count Data Written
vs1 volume_1 0-5 2 17MB
vs1 volume_1 6-10 11 2GB
vs1 volume_1 11-15 54 10GB
vs1 volume_1 16-20 41 3.23GB
vs1 volume_1 21-25 35 15GB
vs1 volume_1 26-30 0 0B
vs1 volume_1 31-35 0 0B
vs1 volume_1 36-40 0 0B
vs1 volume_1 41-45 0 0B
vs1 volume_1 46-50 0 0B
vs1 volume_1 51-55 0 0B
vs1 volume_1 56-60 0 0B
vs1 volume_1 61-65 0 0B
vs1 volume_1 66-70 0 0B
vs1 volume_1 71-75 0 0B
vs1 volume_1 76-80 0 0B
vs1 volume_1 81-100 0 0B
17 entries were displayed.
