security anti-ransomware volume entropy-stat show-recent-hourly-stat
Display the volume entropy recent hourly stats
The security anti-ransomware volume entropy-stat show-recent-hourly-stat command displays the percentage of data classified as encrypted using an entropy algorithm measured at hourly intervals, at the volume level.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name-
This parameter specifies the Vserver of the anti-ransomware enabled volume for which the entropy stats need to be displayed. If this parameter is specified, the command displays entropy stats only for the specified Vserver.
[-volume <volume name>]- Volume Name-
This parameter specifies the anti-ransomware enabled volume for which the entropy stats need to be displayed. If this parameter is specified, the command displays entropy stats only for the specified Volume.
[-timestamp <MM/DD/YYYY HH:MM:SS>]- Start Time-
This parameter specifies the start time of entropy stats collection interval. If this parameter is specified, only rows that match the specified input for timestamp will be displayed.
[-total-data-written {<integer>[KB|MB|GB|TB|PB]}]- Total Data Blocks written-
This parameter specifies the amount of data written in the interval. If this parameter is specified, only rows that match the specified input for total-data-written will be displayed.
[-encryption-percentage <percent>]- Encryption Percentage-
This parameter specifies the encryption percentage of the interval. If this parameter is specified, only rows that match the specified input for encryption-percentage will be displayed.
[-duration <time_interval>]- Duration of the interval-
This parameter specifies the duration of the interval. If this parameter is specified, only rows that match the specified input for duration will be displayed.
The following example displays the recent hourly entropy stats information of a volume.
cluster1::> security anti-ransomware volume entropy-stat show-recent-hourly-stat -vserver vs1 -volume vol1
Total Encrypted
Vserver Volume Start Time Duration Data Written Data%
vs0 vol1 1/27/2025 19:49:39 0h59m8s 500MB 0%
vs0 vol1 1/27/2025 20:48:47 1h0m0s 200MB 0%
vs0 vol1 1/27/2025 21:48:47 1h0m0s 40MB 10%
vs0 vol1 1/27/2025 22:48:47 1h10m52s 1GB 20%
vs0 vol1 1/27/2025 23:59:39 0h59m8s 2GB 10%
vs0 vol1 1/28/2025 00:58:47 1h10m0s 350MB 0%
vs0 vol1 1/28/2025 02:08:47 1h0m0s 77.48MB 13%
vs0 vol1 1/28/2025 03:08:47 1h0m0s 44MB 0%
vs0 vol1 1/28/2025 04:08:47 1h0m54s 3GB 0%
