Command reference
security cluster-network ipsec policy show
Show the IPsec policies for cluster security
The security cluster-network ipsec policy show command displays the IPsec policies used for the cluster security feature configuration.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node <nodename>] - Node Name
Node name.
[-name <text>] - Policy Name
The IPsec policy name used by the specified node for the cluster security feature.
[-auth-method <IKE Authentication Method>] - Authentication Method
Authentication method used by the IPsec policy.
[-cert-uuid <UUID>] - UUID for Certificate
UUID of the certificate used for authentication in this policy.
[-local-ip <IP Address/Mask>] - Local IP
Local IP protected by this IPsec policy.
[-remote-ip <IP Address/Mask>] - Remote IP
Remote IP allowed by this IPsec policy.
[-action <IPsec Action Type>] - Action
Action to take for traffic matching this policy (e.g., protect, bypass).
The following example displays the IPsec policy information for the cluster security feature configuration.
cluster1::> security cluster-network ipsec policy show
Node        Policy Name      Local IP Subnet Remote IP Subnet Certificate UUID
node1       policy1          10.1.1.0/24     10.2.1.0/24      12345678-1234-...
node2       policy2          10.1.2.0/24     10.2.2.0/24      87654321-4321-...
2 entries were displayed.
