security jit-privilege show
Display the JIT configurations
The security jit-privilege show command displays global settings of just-in-time (JIT) privilege elevation.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
The specific Vserver name where the just-in-time privilege settings apply.
[-application <text>]- Application-
The specific application where the just-in-time privilege settings apply.
[-default-session-validity-period <time_interval>]- Default Session Validity Period-
Default session validity period.
[-max-jit-validity-period <time_interval>]- Maximum JIT Validity Period-
Maximum just-in-time validity period.
The following command displays the global settings of just-in-time privilege elevation.
cluster1::> security jit-privilege show
Vserver: vs0
Application: ssh
Default Session validity period: 1h0m0s
Maximum JIT validity period: 2160h0m0s
