security jit-privilege user create
Create a JIT privilege of user
The security jit-privilege user create command creates a just-in-time (JIT) privilege elevation entry for the user which has already been configured.
-vserver <vserver name>- Vserver-
This is the Vserver of the user for whom you are adding JIT entry. When not set, the default value of
AdministrativeVserver is used. -username <text>- Username-
This is the username for whom you are adding the JIT entry.
-application <text>- Application-
This specifies the application of the JIT entry. When not set, the default value of
sshis used. [-role <text>]- Role Name-
This specifies an access-control role name for the JIT entry. When not set, the default value of
adminis used in case of Administrative Vserver andvsadminis used in case of data Vserver [-session-validity-period <time_interval>]- Session Validity Period-
This specifies the validity period for which the just-in-time (JIT) privilege level will remain elevated. When not set, the value specified in the global JIT settings is used.
[-jit-validity-period <time_interval>]- JIT Validity Period-
This specifies validity period within which the user's JIT privilege level can be elevated and/or reset any number of times. The value of this parameter must always be greater than or equal to the value specified for
session-validity-periodparameter. When not set, the default value is taken fromsession-validity-periodof the global JIT settings. [-start-time <MM/DD/YYYY HH:MM:SS>]- Start Time-
This specific starting date/time in UTC format from which privilege can be elevated. When not set, the default value is the current date and time in UTC format.
[-comment <text>]- Comment-
This optionally specifies comment text for the JIT entry.
The following command creates a JIT entry for user named "jdoe" for Vserver vs1.
cluster1::> security jit-privilege user create -username jdoe -application ssh -role admin -session-validity-period 1h -jit-validity-period 5h -start-time "4/17/2023 14:37:58" -vserver vs1 -comment "This is a JIT entry for jdoe"
