security jit-privilege user delete
Delete a JIT privilege of user
The security jit-privilege user delete deletes just-in-time(JIT) privilege elevation entry for the user which has already been configured.
-vserver <vserver name>- Vserver-
This specifies the Vserver of the user for whom you are deleting JIT entry. When not set, the default value is the Administrative Vserver.
-username <text>- Username-
This specifies the name of the user for whom you are deleting the JIT entry.
-application <text>- Application-
This specifies the application of the JIT entry. Possible values include ssh.
The following command associates deletes a JIT entry for user named "jdoe" for Vserver vs1.
cluster1::> security jit-privilege user delete -username jdoe -vserver vs1 -application ssh
